ArchiRADAR Rendering Contest => Topic aperto da: maurop - 19 Febbraio 2009, 14:26
http://www.pushpullbar.com/forums/architectural-models/10408-michel-rojkind-pr34-house.html
se avete tempo, voglia, piacere
buon lavoro :wink:
un 3ds di può avere? o solo artlantis?
A tacos, ce sta pure il file in schetciup
:ok:
come mai gli altri file non me li scarica neanche le immagini?
se sei un nuovo iscritto........come ti scrivono il alto nella pagina...hai alcune limitazioni....
scusate ma non ho mai fatto contest come funziona?
ho scaricato il file, ora smanetto un pò per cercare di fare qualcosa di carino e poi lo posto? scadenze... altre cose...
e da un po che sono iscritto, prima mi faceva scaricare, ma quando finiscono questa limitazioni?
"[pushpullbar]2 forum encourages members to participate in the forum discussions and sharing. If you haven't been posting anything or haven't reached a minimum number of genuine posts, either in the form of discussion, critique or even technical help as part of our community, you have been put into a special user group called 'Registered Non-Participants'. This usergroup has all the forum features enabled for Registered Active Member except for downloading and viewing images in the Designer Components Depot and Architectural Models forums. That is a measure to stop people just registering to download the components without participating in the forums. Reading and contributing is not limited as a 'Registered Non-Participants'! You still have full access to all the threads, just not file downloads. All you need to do is to prove you are a genuine participant of the forum to gain access. It doesn't matter who you are, what your degree is, and what experience you have... as long as you are participating in the forums, you shall expect critiques, questions and ratings. If you are not participating, don't expect anything in return."
ricordiamoci che gli amministratori di questo forum hanno più volte richiamato all'ordine un certo NICOLAS RIVERA perchè postava immagini senza poi dare chiarimenti su settagggi o trucchi....
sono molto esigenti con i loro frequentatori.......
ho scaricato la scena di skectup, salvata poi in 3ds ma viene una ca..ta....
qualche anima pia che fornisce un 3ds?
l'inglese non l'ho mastico tanto bene, essendo esigenti si deve far qualcosa per far si che ti permettino di scaricare?
Un paio di prove veloci, dove risaltano i problemi del file di sketchup.
Un interno reinterpretato da mè... spero vi piaccia, la texture del calcestruzzo non è il massimo....
se volete commentate :ok:
....dove risaltano i problemi del file di sketchup.
...stai parlando delle curva frammentata?In compenso,però....che gnocca!!! :ok: :ok: :D :D :ok: :ok:
@bazHELL
L'illuminazione è abbastanza buona.Peccato la bruciatura all'esterno......e la textur del cemento che,come hai detto,non rendering :ok: :D
:D è un vero peccato che la texture del calcestruzzo sia così poco definita...
anche la bruciatura esterna non è il massimo ma è il meglio che ho potuto fare, perchè se diminuisco l'illuminazione poi perdo luce all'interno... :wondering:
