ArchiCAD
oggetti ArchiCAD, ArchiCAD object with problem, objeto de ArchiCAD con problemas
Topic: oggetti ArchiCAD, ArchiCAD object with problem, objeto de ArchiCAD con problemas (Letto 1179 volte)
Marco Hernandez
Newbie
Post: 1
29 Settembre 2009, 17:13 »
hello everybody, i have a problem with an ArchiCAD object. Falda by Bruno Some, the script indicates an error; could someone tell me what do i have to fix? thank you!
Ultima modifica: 29 Settembre 2009, 17:42 da lucio vero
Arq. Marco A. Hernandez
Che pacchia un forum senza spocchia!
ADMIN
Post: 5.107
Re: oggetti ArchiCAD, ArchiCAD object with problem, objeto de ArchiCAD con problemas
29 Settembre 2009, 18:00 »
If you dont' report what the error says, it is difficult to argue. But there are chances that it needs some object or attribute only found in the Italian package of ArchiCAD.
archiradar Staff
ArchiCAD
