Autore Topic: aggiornamento artlantis da 3.0.3 a 3.0.5 e alpha a 64 bit  (Letto 13609 volte)
gbigagli
  • Post: 69
Ho visto ieri che artlantis ha pubblicato un aggiornamento sia di artlantis render che studio dalla 3.0.3 alla 3.0.5. Inoltre pubblica anche l' alpha a 64 bit. qualcuno ha già provato a fare l' upgrade? ...(per capire se vi sono stati problemi) grazie
giacomo
Hedy
  • Post: 310
Re: aggiornamento artlantis da 3.0.3 a 3.0.5 e alpha a 64 bit
« Risposta #1 il: 16 Novembre 2010, 13:37 »
Un solo giorno mi pare un po' poco per pareri .. anche perchè non ho idea di che cosa abbiano corretto. ;-)
« Ultima modifica: 16 Novembre 2010, 13:40 da Hedy »
"Un pixel alla volta.."
  • Post: 11.629
« Risposta #2 il: 16 Novembre 2010, 14:51 »
Fixes since version 3.0.3
Fixes:
- When opening an atl archive, when a .mov linked file was a mp3 audio file, a dialog asked for this file, Cancel Artlantis quitted unexpectedly.
- It was impossible to open an .atl file version 1.2 in version 3.0.3. - Lighting thou the lights were turn off they kept casting shadows. - Artefacts black dots fixed. - FBX importer fixed, objects get their geometry offset. Enhancements:
- Import of DWG-DXF 2011 files.
Fixes since version 3.0.0
Fixes:
- changing the anchor point of an object with « camera target» option was ineffectual. - by the end of a VR rendering a new saving dialog get displayed. - Post process: Edge and Pastel: the cursor Pastel Effect was ineffectual. - crash when opening some atl files.
- texture had a round artefact. - merged geometry was ineffectual. - UV textures of objects were not correctly displayed. - Postcards preview drag and drop of Shader was ineffectual. - aof files had a tiny preview. - crash when Undo was used after the “Merge Geometry” command. - obliged to enter the coordinates of the camera more then one time to get them. - icons size issue of Artlantis in the Dock. - display issue when resizing the 2D View window. - light inspector the popup menu «Target On» didn't refresh when doing "Use as Target" on an object. - water shader “Flatness” cursor the tooltip was wrong. - Revert function could crash Artlantis. - point of views inspectors could disappear. - a dwg file had no triangle thou it contained 3D geometry.
Exporters:
- ArchiCAD 13 to Artlantis 3 impossible to use « Use a Reference File... » from the export. - an OBJ export did not get exported. - an ArchiCAD 12 file crashed when exporting to Artlantis 3 - when exporting to ArchiCAD 12 and ArchiCAD13 to Artlantis 2 and Artlantis 3 texture orientation could be lost.
- Artlantis crahed when opening a dwg file. - the GDL materials of binary objects were not listed into Artlantis
Abvent November 2010
« Ultima modifica: 16 Novembre 2010, 14:57 da Robs »
« Risposta #3 il: 16 Novembre 2010, 14:55 »
    ... questa cade proprio a fagiolo .....  :D ... ma dove erano internate ste notizie????????
  • Post: 11.629
« Risposta #4 il: 16 Novembre 2010, 14:58 »
All'interno del pacchetto dell'upgrade ...    ;-)
« Risposta #5 il: 16 Novembre 2010, 15:02 »
.... beh certo dare la notizia come fanno tutti in homepage era troppo x abvent ...  :whistling:
Hedy
  • Post: 310
« Risposta #6 il: 16 Novembre 2010, 15:07 »
scusate, mi rendo conto di essere fuori dal mondo, ma riassuntino in italiano?
l'inglese non è il mio forte  :worried:
  • Post: 11.629
« Risposta #7 il: 16 Novembre 2010, 15:24 »
Più o meno questo:
correzioni rispetto alla versione 3.0.3:
- all'apertura di un archivio .ATL, nel caso in cui un file .mov è collegato a un file audio mp3, un dialogo domanda di cercare questo files. Per annullare occorre chiudere il programma.
- è impossibile aprire un file .atl versione 1.2 con la versione 3.0.3
- le luci artificiali anche se spente continuano a produrre ombre
- correzione dei punti neri sulle superfici
- correzione dell'importazione FBX, una parte della geometria degli oggetti veniva spostata
miglioramenti:
- importazione dei file DWG-DXF di autocad 2001
speriamo che i punti neri di qui parlano siano la correzione delle macchie scure sulle superfici quando si alzano i rimbalzi del radiosity
« Risposta #8 il: 16 Novembre 2010, 15:36 »
.... beh anche la correzione della geometria spostata nell'import degli fbx non è male  .....  ;-)
Hedy
  • Post: 310
« Risposta #9 il: 16 Novembre 2010, 16:29 »
Grazie per la traduzione Robs  :bowing:
  • Post: 5.389
« Risposta #10 il: 16 Novembre 2010, 17:45 »
Ho riprovato a installare la versione a 64 bit per mac........
 :shoked02: Non funziona a 64 bit....... :shoked02:
Che mi combinano sti ragazzi della Abvent??????  :gun2:
« Ultima modifica: 16 Novembre 2010, 17:47 da antonibon »
  • Post: 11.629
« Risposta #11 il: 16 Novembre 2010, 18:13 »
ma hai avviato il mac a 64bit ??  E poi, hai più di 4GB di RAM ? Altrimenti non ha senso...
  • Post: 5.389
« Risposta #12 il: 16 Novembre 2010, 18:21 »
8gb di RAM...... altri programmi me li da a 64 bit...... quindi non penso sia questione di avvio.......
La versione precedente partiva a 64 bit senza variare nulla all'avvio.......
  • Post: 11.629
« Risposta #13 il: 16 Novembre 2010, 18:25 »
Fai una prova ...
  • Post: 5.389
« Risposta #14 il: 16 Novembre 2010, 18:48 »
Per essere sicuro ho riavviato il sistema forzandolo a 64 bit (tasti 6 - 4 premuti).... non cambia nulla........
ho verificato con il system profiler.... ed il kernel me lo da a 64 bit.......
« Ultima modifica: 16 Novembre 2010, 18:50 da antonibon »
  • Post: 11.629
« Risposta #15 il: 16 Novembre 2010, 19:00 »
Bhè, allora, se sei sicuro di aver scaricato la versione giusta dal sito Abvent, gli dovresti scrivere per segnalare il problema ...
  • Post: 5.389
« Risposta #16 il: 16 Novembre 2010, 19:10 »
La schermata iniziale parte con la scritta in rosso "Versione Alpha 1 - 64 bit".......
  • Post: 11.629
« Risposta #17 il: 16 Novembre 2010, 19:14 »
Senti, ma hai scaricato l'upgrade di 18MB oppure la release completa di 308mb ??
Non è che hai fatto l'upgrade alla versione a 32bit?
Prova a scaricare tutta la versione completa di 308mb. Forse con quella risolvi.
« Ultima modifica: 16 Novembre 2010, 19:18 da Robs »
  • Post: 5.389
« Risposta #18 il: 16 Novembre 2010, 19:26 »
E' con quella da 308 mb che ho provato....... la precedente l'avevo già eliminata dal mac
  • Post: 5.389
« Risposta #19 il: 16 Novembre 2010, 19:32 »
Gli ho scritto....vediamo che dicono.....
