altro upgrade per archicad 11...
http://www.graphisoft.com/ftp/techsupport/downloads/ac11/AC11-1200.exeList of most important bugs fixed in this Hotfix:
65087 CRASH - In navigator, while trying to modify master layout settings with multiple layouts selected.
61159 CRASH - In rare occasions, file is saved with bad data structure and causes crash when opened again.
64468 CRASH - When opening certain legacy ArchiCAD files.
73180 CRASH - When placing certain PDF files as drawing.
66266 CRASH - When splitting several elements at the same time in a Detail view.
65776 CRASH - When Zooming while dragging several elements on a Layout.
70184 CRASH - While editing wall thickness in certain situations.
67090 DOCUMENT - Automatic Dimensioning tool dimensions rotated rectangular columns incorrectly.
66306 DOCUMENT - Automatic Dimensioning with 'Core only' option - full width of composite walls are dimensioned.
67145 DOCUMENT - Deleted segments of Interior Elevation marker still appear on layouts.
68223 DOCUMENT - Door orientation parameter does not update after undoing a mirror action.
69540 DOCUMENT - In certain situations source markers can not be linked to a drawing derived from that source marker.
67965 DOCUMENT - Overlapping column and wall do not miter in layout views, even though on floor plan they appear correctly.
69929 DOCUMENT - Shadow casting is sometimes wrong when building elements overlap.
68297 DOCUMENT - The text settings of the Interior Elevation marker are reset when the ID number is changed from the Navigator.
70541 DOCUMENT - Zone materials are not listed correctly in Interactive Schedules.
68081 EDIT - Wrong grouping of elements in detail views after 'Rebuild from Source view' command.
70422 I/O - Extra lines appear in PDF outputs in rare occasions.
70584 I/O - In certain files library parts are missing from plan, even though the library parts are loaded.
69057 I/O - In rare occasions, not all pages of a multi-page Interactive Schedule document is printed or saved as PDF.
67771 I/O - Publishing layouts with "selected items" option - the output file will not inherit the new layout name, if it was changed since a previous publishing session.
71726 I/O: Some PDF files placed as drawings appear rotated in PDF output.
66304 I/O: Texts using certain (not commonly used) font types are missing from PDF output. A registry key has been introduced that changes font embedding settings, resulting in larger PDF files. Use only if you are experiencing the problem. Read more at: archicadwiki.com/Bugs/Text_missing_in_PDF
73420 OPTIONS - If Cadimage Door/Window builder add-on is loaded, zone categories are deleted after Attribute Manager is closed.
72406 SPEED - 2D pan and zoom is slow if there are many views in Navigator or Organizer.
72983 SPEED: Creating schedules that list elements in relation to zones is slow if the file is large.
69653 TEAMWORK - External drawings placed in sections, details or Worksheets are missing from Drawing manager after Send and Receive.
71106 VIEW - Feedback lines are missing after certain combination of events.
