Autore Topic: update ATL2  (Letto 6682 volte)
lonelystar
  • Post: 100
Re: update ATL2
« Risposta #1 il: 23 Aprile 2008, 17:02 »
Solo per Piccì ... 8)
ArchiCAD 12 - Artlantis Studio 2 - OSX 10.5
G5 2,7Ghz - PowerBook Ti 17' 1,5Ghz
Imac 20"/2,4Ghz e Iphone 3G
"Ciò che non mi uccide mi rende più forte" -- F. Nietzsche
Re: update ATL2
« Risposta #2 il: 23 Aprile 2008, 17:14 »
scusa LOL...rispetto l'anzianità.....ma   se poni un click sulla vostra beneamata mela..............vedrai un file di 40 mega da scaricare  8) 8) 8) 8) 8) 8) 8) 8)
max respect  :wink:
sheva
  • Post: 1.177
Re: update ATL2
« Risposta #3 il: 23 Aprile 2008, 17:17 »
Ora ci sta...prima non ci stava
S&S4all
archiradar Moderator
MacOsx10.9_MPB retina_iMac
Art6beta_archicad 17
KeepCalmAndCarryOn_S&S4all!
Michele
  • Post: 580
Re: update ATL2
« Risposta #4 il: 23 Aprile 2008, 17:18 »
max respect  Wink
:lol: :lol: :lol:
lonelystar
  • Post: 100
Re: update ATL2
« Risposta #5 il: 23 Aprile 2008, 18:03 »
prima nun ce stava Mau fidati.... :wink:
peace and love
Re: update ATL2
« Risposta #6 il: 23 Aprile 2008, 18:03 »
   Testo tradotto automaticamente:
Artlantis 2.0.1 Update Installation: - Mac OS X plateform: Double click on Artlantis201Update.pkg, follow the displayed instructions. - Windows XP:plateform: Double click sur Artlantis201Update.exe, follow the the displayed instructions. Enhancement since version 2.0.0 Enhancement: Vegetation behavior, for the South hemisphere seasons are now reversed. Space Navigator has been calibrated again Fixes since version 2.0.0 Fixes: - the option On/Off for a lamp couldn’t be animated. - animated people lost their textures once saved as archive. - crash when replacing an object by an other one. - crash when duplicating a panorama - option sky mix color, the option get unchecked - site insertion tool outil the magnify tool when scroll with the wheel of the mouse made the background disapeared. - on Mac Heliodon when entering the time didn’t match with the typed. - crashes in final rendering fixed. - radiosity problem in high value fixed. - batch rendering the state column didn’t report the state info. - bad reflection in the shadows using the mix de color. - under Windows the Catalogue was compressed in the bottom of the window. - Catalog if the images were set to invisible the Postcards did hide too. - exported textures from ArchiCAD 11 the accentuated characters were lost. - on Windows impossibility to resize the Catalog window. - drag and drop of a shader from a Postcard not available when the preview size was not at max size. - animation impossibility to duplicate keyframes. - QuickTime codec list characters downgraded. - under Windowsthe Postcards installed didn’t work - Shader Gravel_05: Gravel_05_b.jpg didn’t get applied as a Shader but as a texture. - on Mac PPC: crash when opening an archive realized on Mac Intel. - on Mac PPC: drag and drop of an animated people had no effect. - Objects list: crash when using the magic wand tool. - Dosch objects displayed into the Catalog some get displayed with their associated textures get too. - Billboards didn’t faced the camera when constraint. - animation: a looped movie didn’t loop - Shader Expert the transparency was not taken into account in the final rendering. - the rendering time displayed was wrong. - render later: images were replaced even if the option was not activated. - under Windows the Catalog size was not retrieve on a 2d monitor. - Use a Reference File: the texture were not placed at their right position. - Parallel Views the Infinite Ground didn’t received shadows when the soft shadows were On. - VR Objects and Panoramas it was difficult to change the point of view. - VR Objects rendering if the .mov conversion failed the tga backup was delete. - some geometry could missed into the 2D View. - into the Windows taskbar the name didn’t indicate the name of current atl file. - sorting in the Material list didn’t work. - animation: Timeline window: duplicate a key frame with alt key didn’t duplicate at once. - lights: in 2D View moving the target of the light to the source made the light jump. - the list of the short cuts Abvent April 2008
Installazione:
-- Mac OS X Plateform:
Fare doppio clic su Artlantis201Update.pkg, seguire le istruzioni visualizzate.
-- Windows XP: Plateform:
Fare doppio clic sur Artlantis201Update.exe, seguire le istruzioni visualizzate.
Valorizzazione dalla versione 2.0.0
Valorizzazione:
Vegetazione problema, per l'emisfero Sud stagioni sono invertite ora.
Spazio navigatore è stato tarato di nuovo
Correzioni dalla versione 2.0.0
Correzioni:
-- L'opzione On / Off per una luce non poteva essere animato.
-- Animate persone hanno perso la texture, una volta salvati come archivio.
-- In crash quando si sostituisce un oggetto da un altro.
-- In crash quando duplicare un panorama
-- Opzione cielo mix di colori, l'opzione deselezionata arrivare
-- Inserimento sito strumento strumento strumento di ingrandire il momento di scorrimento con la ruota del mouse sullo sfondo fatto disapeared.
-- Su Mac Heliodon quando si entra il tempo non corrisponde con la digitato.
-- In crash finale di rendering fisso.
-- Radiosità problema in alto valore fisso.
-- Batch rendere la colonna Stato non ha relazione lo stato informazioni.
-- Cattivo riflessione nelle ombre utilizzando la combinazione di colore.
-- Sotto il Catalogo di Windows è stato compresso in fondo alla finestra.
-- Catalogo se le immagini sono state fissate per il invisibile Cartoline ha fatto nascondere troppo.
-- Texture esportate da ArchiCAD 11 i caratteri accentuati sono stati persi.
-- Su Windows impossibilità di ridimensionare la finestra di catalogo.
-- Drag and drop di un shader da una Postcard non disponibile quando la dimensione di anteprima non è stato a dimensione massima.
-- Animazione impossibilità di duplicare keyframe.
-- Elenco di codec di QuickTime caratteri declassati.
-- Sotto Windowsthe Cartoline installato non ha funzionato
-- Shader Gravel_05: Gravel_05_b.jpg non avere applicato come una Shader ma come una texture.
-- Su Mac PPC: crash quando si apre un archivio realizzato su Mac Intel.
-- Su Mac PPC: drag and drop di un animato persone non ha avuto alcun effetto.
-- Oggetti lista: crash quando si usa la bacchetta magica strumento.
-- Dosch oggetti esposti nel Catalogo ottenere alcuni visualizzate con il loro associati texture troppo.
-- I cartelloni non ha affrontato la fotocamera quando vincolo.
-- Animazione: un cappio film non ha loop
-- Shader esperti la trasparenza non è stata presa in considerazione nella finale di rendering.
-- Il tempo di rendering è stato visualizzato sbagliato.
-- Rendere più tardi: le immagini sono state sostituite anche se l'opzione non è stato attivato.
-- Sotto Windows il Catalogo dimensione non è stato recuperare su un monitor 2d.
-- Utilizzare un file di riferimento: la trama non sono stati messi a loro giusta posizione.
-- Visite parallelo l'Infinito Ground non ha ricevuto quando le ombre morbide ombre sono state On.
-- VR Oggetti e Panorami era difficile cambiare il punto di vista.
-- VR Oggetti di rendering se l'. Mov conversione non il tga di backup è stata eliminare.
-- Alcuni geometria potrebbe perdere in vista 2D.
-- Nella barra delle applicazioni di Windows il nome non ha indicato il nome del file corrente Atl.
-- La cernita in elenco il materiale non ha funzionato.
-- Animazione: Cronologia finestra: duplicare un fotogramma chiave con alt chiave non duplice esemplare a una volta.
-- Luci: Visualizza in 2D di spostare il bersaglio della luce alla fonte fatto saltare la luce.
-- L'elenco delle scorciatoie
Abvent aprile 2008
lonelystar
  • Post: 100
Re: update ATL2
« Risposta #7 il: 23 Aprile 2008, 23:04 »
 :clap: Bella li Mauro
Gracias   :wink:
Re: update ATL2
« Risposta #8 il: 24 Aprile 2008, 07:36 »
.... scusate se mi intrometto ....  8) .... ma il vizietto delle bb che vanno in giro per i fatti loro ... lo hanno corretto??!! ...  8)
.... la seghettatura nei render delle sezioni ... lo hanno corretto ??!!  :shock: :lol:
Re: update ATL2
« Risposta #9 il: 26 Aprile 2008, 10:28 »
...... domandina ? .... come si sà .... una volta installata la demo di un programma ..... questi alla scadenza dei 30 gg. smette di funzionare .....
ora io mi/Vi chiedo .... x tutti coloro che hanno già installato e terminato i 30 gg. canonici di prova .... è possibile installare quest'aggiornamento e quindi provare tutte queste migliorie apportate ad ATL2 .... oppure lo riconosce come il primo è quindi ti rimanda all'acquisto???  :lol:
« Ultima modifica: 26 Aprile 2008, 16:45 da antonibon »
Re: update ATL2
« Risposta #10 il: 26 Aprile 2008, 16:47 »
è possibile installare quest'aggiornamento e quindi provare tutte queste migliorie apportate ad ATL2[/b] ....
se sono passati i 30 giorni il programma si blocca e non ti permette di provare le migliorie
vedi sopra....
Re: update ATL2
« Risposta #11 il: 26 Aprile 2008, 16:53 »
GRAZIE Antonello ....  :P
Re: update ATL2
« Risposta #12 il: 16 Maggio 2008, 16:57 »
edo.7
  • Post: 1.424
Re: update ATL2
« Risposta #13 il: 16 Maggio 2008, 17:42 »
ma si sa niente di quando saranno disponibili gli aggiornamenti per chi ha acquistato artlantis nel 2008???
                       prua verso l'altra gente...."
