ArchiCAD plug-in for Maxwell Render 1.7
Aperto da Peter, 19 Giugno 2008, 20:04
Peter
Product sheet
Whats New
Improvements and fixes
• The Physical Sky parameters were modified to fit the Maxwell Render 1.7 model.
• Support for generating Maxwell material previews of ArchiCAD materials was implemented.
• The ArchiCAD material panel now has a visual material browser for MXM files.
• The material panel was completely redesigned with sliders for easier material set-up.
• Foam core rendering functionality is now available. This function renders a model with a default light gray color for all materials and transparency: great for studying lighting and shadows.
• The Maxwell Render logo icons were added to all Maxwell Render panels for easier recognition.
• Date/ time control added to the environment dialog (improvement over setting the month/ date/ hour in simple UI).
• Shadow channel added to the layers/ channels dialog.
• "Disable Bitmaps" functionality is now available.
• Tone-mapping parameters added.
• ArchiCAD materials now take into account ArchiCAD transparency (AGS based materials).
• Transparency enabled in ArchiCAD's Maxwell material panel.
• Support for "Setting Emitter Color" using "Color Temperature" added.
• Presets for emitters implemented for ArchiCAD materials. The same presets found in MXED can now be used in ArchiCAD directly, allowing for a workflow improvement. Simple emitters do no longer have to be created as MXM but can be created in ArchiCAD directly.
• Plug-in for ArchiCAD 12 now available.
• Fix: clear MXM material button works properly now.
• Fix: texture maps were sometimes flipped on Mac OSX.
• Fix: emitters created using automatic material conversion now use the color emission color of ArchiCAD.
• Fix: MXM materials with no preview are properly handled in both the material browser and the material panel: they sometimes caused crashes.
P.
